jerem0621
Jun 05, 2016Explorer II
The pro series hitch you linked to is a fine and affordable hitch. It's dual jaw design is great and is self latching.
The slider base is one thing I have a bit of an issue with Reese/ProSeries. Other brands of hitches use solid bar stock machined to be a slider rail while the Reese/ProSeries base is a welded hollow tube. It's plenty strong enough but by virtue of design it only has 10 inches of travel...other slider bases such as B&W and Curt give a full foot of sliding...those extra two inches may or may not matter. Just something to consider.
One other plus to the Reese/ProSeries is that it is one of the lightest slider hitches on the market. I believe the shipping weight is around 150 lbs and the Curt and B&W is over 200.
I like the versatility that the above bed rails give... Extra tie off points for securing cargo when hauling stuff while not towing... Add a cheap ProSeries gooseneck plate for your fifth wheel rails and you have a gooseneck hitch and can haul gooseneck trailers if you need too...no gooseneck ball to get stuck in your bed etc etc etc
Thanks!
Jeremiah
Thanks!
Jeremiah
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
