Jonny8491's avatar
Jonny8491
5th wheel hitch question
I am new to 5th wheel trailers. We just bought a 2004 dutchman 5th wheel. I am having a Curt Q20 hitch installed in my 2012 2500HD Chevy Crew Cab with 6.5' box.
My question......Do I need rollers/slides on my hitch?
thanks much
Jonny
  • This is an age-old question and you will get many answers, all valid for that person and his or her truck and trailer combination. I have an antique trailer with a very square front and I use my slider every time I pull into a campground. Watching the corners is one less thing to worry about. Given the difference in cost between a slider and a nonslider, you could pay more than that for one mistake that crushes the corner of the truck and takes out the rear window. Good luck and welcome to the forum. Lots of good people here!
    Bob
  • You mean a sliding hitch I assume. You either buy a slider or you don't it's not an addon. If you are careful when you turn the fifth wheel you should be OK with a standard hitch, so long as the 5ver has the modern style rounded front cap. The problem arises when you get near a 90 degree angle between the trailer and truck cab. You don't want the front cap to bang into the back of the truck cab.
    BK
