austingta wrote:
garyp4951 wrote:
Frank thats an awesome truck you have, but when looking at 5er's I would stay under 13k gross weight.
I've been looking at the Duramax's lately also.
I will. I'm planning to stay below 10000 empty. That seems easy enough to find in a 32' or less 5'er.
Ignore the "empty" numbers. Depending on CCC (cargo carrying capacity), you may or may not be OK. Always work with the GVWR of the fifth wheel - including estimating the loaded pin weight (23 - 25%). The GVWR for the RV is on a sticker on every RV.
Rob
