edhensley wrote:
bpounds wrote:
Doesn't the center bolt always just bolt to the bed? Only the outer ones connect to the frame on my rails. And if I recall correctly the center bolt is optional except when used with hitches greater than 16k cap.
I think that rail needs to simply be removed and straightened.
If it isn't too much bother, I would like to see a picture of the issue.
I would think twice about straightening, that would reduce the hardness unless a new heat treat. The people saying a picture would be nice are correct. If it is minor and not changing or bending the bed, you should be OK, if it is not minor or still bending you should replace it.
Nah, there's nothing heat treated about those rails. Just formed steel. Drill 'em, weld 'em, bend 'em, you can't hurt 'em.
