kaydeejay
Jun 26, 2014Explorer
luckyc1423 wrote:That 16000# may be the tow capacity of the F350 SRW but does it have enough payload capacity for 3200#+ of pin weight, plus hitch weight, plus occupants and "stuff" plus a tank of fuel?
I will probably buy a toy hauler around 33' - 39' that weighs less than 16,000 pounds because that is the limit of the SRW F350 truck. I am probably either looking at a Keystone fuzion, Keyston Raptor, a Spartan, or any of the Heartland models. (Not sure if you need to know that for hitch selection)
I plan on buying a 2015 F350 SRW truck (short bed). I am in sales so the truck being SRW is most important as I go in and out of downtown alot here in houston...................
You might want to check your numbers carefully - tow capacity is only half of the equation. On anything other than a DRW you will usually run out of payload capacity before you hit that max tow number.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
