retispcsi
Jun 27, 2014Explorer
If you are going to buy a Ford do order the hitch prep package. B&W makes two hitches that will work right out of the box. They have the turnover which will fit on the goose neck. Hitch. They also have the model 3300 which will fit into the four puck system. I run a B&W 3300 in my Ram and the hitch is great. B & W also make a slider if you decide to go that way. As far as air bags Air Lift and Firestone both make good products and are easy to install. Also check your weights and make sure you have enough truck for what you want to do. It is easy to look at weights in a brochure but when you load the rig and start down the road it does always work the best. Good luck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
