glazier
Jun 29, 2014Explorer II
ApexAZ wrote:
The B&W Companion is supposed to be pretty easy to remove, so I'm thinking that coupled with a sidewinder pin box might be a great solution for a 6.5 bed if they are compatible?
Not with the single point turnover ball socket. You can use a sidewinder with a puck mount Companion. If your thinking of a Sidewinder pin box, you might want to look at other brands of hitch. Reese, Curt, are just a couple that come to mind. If only towing a fifth wheel ( no gooseneck ) with a standard bed truck, I would look hard at Superglide.
About Fifth Wheel Group
