MFL
Jan 14, 2021Nomad II
Durb wrote:
The installation instructions for the 3300 show the hitch head supports to be installed in two positions. One is 1" in front of the axle, the other is 3" in front of the axle. I don't see any accommodation for 2" behind the axle. The hitch will only serve to reduce your cab clearance.
You are correct, won't be behind axle. It will be 1 inch in front of axle center, but not really in front of axle.
If the OP did not use his previous slider in 13 years, with his Ram, he will now have several more inches of clearance with his new Ford.
Jerry
About Fifth Wheel Group
