Dayle1
Dec 26, 2013Explorer II
OffTheRoadAgain wrote:alboy wrote:
Why not go to a Anderson ultimate hitch that fits right onto the ball, pretty slick and light weight.
What's the consensus on that? Would it be safe enough?
The Anderson Ultimate is a good choice for your situation, but if the existing GN frame mount is only tack welded and no frame bolts, you should beef up that mount before towing. The height of the Ultimate hitch will put a greater lever on the ball mount than the normal ball and could easily lead to weld failure.
Or, you can add fifth wheel rails in front and back of the GN ball and use any fifth wheel hitch you wish. Although getting the additional frame brackets installed might be challenging. Or, grind off those welds and remove the GN ball mount entirely. If you decide on a straight fifth wheel setup, then get the custom, no drill frame brackets for your specific truck.
About Fifth Wheel Group
