I just had a used reese manual silder installed.My question is, there are no grease fitting on this unit. Should I disassemble the unit and grease all the pivot points?
I have the Reese manual slider as well. Prior to use and then monthly thereafter, you need to spray white lithium grease on the underside of the leaf spring in each side assembly. I put grease on the roller pins and the top of the rails as well.
