im ordering the one in the link above... seems like a standard GN ball... Thats good news then...
laknox wrote:
joe_dejesus wrote:
Me Again wrote:
http://www.hitchcrafter.com/30kscrewinball.htm
thank you! I emailed Andersen to verify they support this ball.
my gooseneck frame mount is one piece, not 3 pieces like I see current gooseneck hitches. When installed they needed to lift bed to install the steel bracket onto the frame. The mount looks professional meaning doesn't look like it was made/cut from steel.
Andersen really has nothing to say about the ball. So long as it's a standard GN ball size, the Andersen should fit it. The AU uses a cross pin that goes crossways under the bulge of the ball, then uses a draw-down bolt to pull the hitch down tight to the bed. Pretty simple system. The rest it tweaking the hitch and/or pin box.
Lyle
