dmax_ed
Aug 17, 2020Explorer
5th wheel hitch
Planning to buy a Artic fox 28-5 with a gross weight of 15700 lbs when fully loaded. I have a good deal on a B&W Patriot 16000 lbs of tow weight is this to close to max weight of RV or go with a 18000...
way2roll wrote:twodownzero wrote:
An online search suggests this trailer weighs 9700 pounds, I'm pretty sure it doesn't matter what hitch you use for that.
Not sure where you found that. The specs are : Dry 11,560, payload 4,440, GVWR 16,000, Pin weight 2,435.
Link
You certainly could use the 16k hitch if you didn't load it to capacity, but if you get close to capacity you'd be right at max. To me, paying the few hundred extra to get the 18k not only gives you extra assurance, it also doesn't paint you in a corner when looking at new FW's in the future.
