dmax_ed
Aug 17, 2020Explorer
5th wheel hitch
Planning to buy a Artic fox 28-5 with a gross weight of 15700 lbs when fully loaded. I have a good deal on a B&W Patriot 16000 lbs of tow weight is this to close to max weight of RV or go with a 18000...
Me Again wrote:Cummins12V98 wrote:4x4ord wrote:
^^^ I realize my story is not an apples to apples example. The point I was hoping to get across from it was that if a well built hitch is used at double its rated capacity and something goes wrong the hitch is not likely going to fail. I would be afraid to get on an elevator if I thought I couldn't trust the rated capacity of hitch.
Just twisting your bones! Everything has a "FACTOR" built in and B&W's is VERY high.
My MORryde IS axles are rated 8k, they actually inspected mine that are at nearly 9k and they said they looked good and were within their spec!
You still need Lucy to shed some rocks!
