I have been thinking about moving to a heaver rated 5th Wheel Hitch. We currently have a 16k Husky Hitch in our 3500 GMC DRW pulling our Jayco Pinnacle. Our Pinnacle weights about 15,400 lbs. lo...
If you've been happy with the Husky, why not getting another Husky with the higher weight rating? You have quite a few to choose from...you can probably use your original rails that the 16K Husky is mounted on to go to a higher rating Husky or Reese or several others, unless you're wanting to go a completely different route as far as hitches go....
