klr650goldwing
Jan 27, 2020Explorer
5th wheel hitches
We are about to buy a newer truck. It will be a 2017 F350. We'll be pulling a Solitude which weighs about 12,650 lbs. empty. What hitch would you recommend for that setup?
walker111 wrote:
Another happy BW owner here. 2 pieces about 50 pounds each and so solid in the puck system . Had a curt slider before and that thing was 250 pounds!!!!
klr650goldwing wrote:
The new (for us) truck will be a 2017 Ford F350 6.7 SD, CC, LB, 4X4, 4.10 King Ranch. I would assume it has the puck system.
Cummins12V98 wrote:ChuckV1 wrote:
I'm all in on the B&W, as stated it can be hitched and unhitched with RV and Truck on different planes no issue. They are simple and solid with no question if your hitched connections. B&W's head pivot point is right at the kingpin's height. All of B&W's products are Made In USA.
I also use a 1/8" this slip plate, by Hensley...
Safe Travels :)
**** Dude, you been reading my B&W posts?
Safe Travels :)
