NC_Hauler
Jan 16, 2014Explorer
Michelle.S wrote:
OK, years ago, the number did generally mean something, and it generally was the overall length. We had a Fleetwood Prowler 24M, was 24' from hitch to bumper with 21' actual inside space. Our next TT a Gulfstream Conquest was a 26XXX (forget the letters), but was actually 26' box, making for approx 30' overall.
2010 Montana 2955RL (same model posted earlier at 32') ours was 34'. Now current Redwood is a 36RL, brochure length of 38'11", but it's measured from the King Pin back, actual spec drawing length is 40'2" tip to tail and 409 SqFt.
Oh, in reference to an earlier post that model numbers told you which model is bigger, not always the case as with Montana, 3400/3402 are one of the bigger models, yet many smaller have higher model numbers.
So in the End, as has been said many times, get out the trusty tape measure and get to the scales, only way to know for sure.............
Still find it hard to believe that the manufacturer doesn't post exterior lengths, ie from as far out front as the 5er extends, whether it be the pin or the front cap, to the very end, be it a bumper, spare tire or the ladder....used to be they did it all the time, and again, if one checked it with their trusty tape measure, would find it within an inch or two of actual front to back measure...unless some don't understand what exterior length includes.
also if one add's a bike rack or a carrier to the back of their 5er or TT, they need to add that additional length to the unit...
I believe it's already been established that the numbers may or may not mean much of anything...all I was recommending, in the scheme of things, "IF" one doesn't have a tape on them and they're trying to figure out length of the unit, (which WAS original topic), 99% the exterior length is listed in the manufacturers brochure that should be found at the dealership....if it's an older unit....carry your tape measure around with you, (I keep a 50' tape measure in my trucks tool box)..
About Fifth Wheel Group
