johndeerefarmer
Jun 16, 2021Explorer III
I have had: B&W Companion, B&W Patriot slider, Pullrite autoslider, Blue Ox slider, AUH and now a Goosebox.
B&W products are heavy and take a tractor or hoist to put in the truck. They also take up a lot of bed space but they work good.
The Pullrite autoslider was junk- if you weren't nearly perfectly straight you couldn't get it to unhitch and second the locking arm that wraps around the ball had to be replaced several time from it getting bent when I would back in.
Blue Ox slider works great but is a pain in the butt to install. You have to get in the truck and torque three bolts
AUH worked ok but doesn't give a good enough turning radius while backing
The Goosebox works great. Ride is good. To hitch up I put a long piece of yellow tape down the center of the hitch and I stick one of those telescoping magnetic balls from Harbor Freight on the gooseball to aid in backing. This hitch gives me the most freed up bed space, also all I gotta do is install the extended B&W gooseball and hitch up. Only downfall is the turning radius backing even with the extended ball isn't as good as one of my previous hitches that had a transport and "backing" position.
From having all of these the Goosebox wins for convenience. Now if it ding the truck from backing up too sharp I might wish I still had my slider.
BTW a gooseneck adapter is NOT what you want. That's a good way to tear up your RV. You want a Goosebox by Reese. There is another company making one but can't remember the name. Good luck
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
