MarkTwain
Jul 11, 2015Explorer
Old-Biscuit wrote:Pholman90 wrote:
No. We double checked it and the pin was in the hitch
Then hitch was NOT latched!
Didn't do a 'pull test' did you??
On Edit:
Found a statement in Reese Installation Sheet
WARNING:
Do Not use this hitch for towing a trailer with a pin box that could come into contact with or interfere with the latch for the hitch handle when turning! (See Fig. 6)
If the pin box contacts the hitch handle or its latch when turning, the trailer may become unhitched
When turning truck to right does front left area of your pin box make any contact with hitch latch/handle????
Reese Instructions
Pg. 4
Also check out Warning on PG. 5
X1---"Do the Brake test after you hook up" the only real way to tell if your trailer is securely hitched properly:):):)
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
