mbrower
Nov 28, 2016Explorer II
blofgren wrote:otrfun wrote:Me Again wrote:Granted, non-use of seatbelts was a contributing factor in this gentleman's death. However, tires, trailer size, truck capacity, and heck, even the placement and design of the concrete median divider, are all potentially part of the underlying cause and effect.blofgren wrote:All fine info, however the failure to wear his seat belt got him killed as I posted in the first post of this thread. Chris
That truck looks like a 2002, but it is definitely not newer than a 2004 because the 2005-2007 model Superduties had a different grille and headlights. In the era of this particular truck the F-250 had a GVWR of 8,800 lbs and the F-350 9,900 lbs. Given it's a crew cab 4x4 diesel, it likely weighs minimum of 7,500 lbs with only the hitch in it. My 1996 F-250 S/C 4x4 SB diesel weighed 6,900 lbs empty leaving a whopping 1,900 lbs for passengers, cargo, hitch, and pin weight.
Did overloading cause this accident? Who knows. Was this truck overloaded towing that toyhauler? Quite likely yes.
As obvious as it may seem, it's important to remember something has to go terribly wrong before you need a seatbelt in the first place. If we ignore this basic cause and effect then we do ourselves a disservice by never learning (or entertaining) the whole truth.
Thank you; it is refreshing to see that someone else actually gets it!
X2.
About Fifth Wheel Group
