Nomad
Jan 17, 2020Explorer
5th wheel tires
What are considered the best tire for 5th wheels today Have a Cedar Creek weighing 11,700 wet and it is time for a change
CALandLIN wrote:cummins2014 wrote:Cummins12V98 wrote:
"So according to YOU, and that inflation chart, I should be inflating those G rated tires at about 70 psi."
YEP, Add 5 psi to the chart.
No I am not the only person doing so.
My Avion had GY "E" tires inflated to 80psi. Changed toy to GY "G" because there were no acceptable US Made "E" tires at that time so I went to the GY "G" tires and the chart said 80 so i ran them at 85psi. Ran this for several years and thousands of miles with perfect tread wear and NEVER hot.
Charts are there for a reason.
It just seems you are the only one promoting it, but if you say so.
Read any replacement tire SOP and they all follow the industry standard that says; the replacement tires MUST, provide a load capacity equal to or greater than, what the OE tires provided at vehicle manufacturer recommended cold inflation pressures.
