Nomad
Jan 17, 2020Explorer
5th wheel tires
What are considered the best tire for 5th wheels today
Have a Cedar Creek weighing 11,700 wet and it is time for a change
Durb wrote:
G rated tires on a 11,700# trailer? Talk about massive overkill. My trailer has an 11,500" GVWR and could have been optioned with passenger tires. I tow with 16" LRE tires and have around a 50% safety margin while towing at approximately 10,500#. I towed with Towmax tires (China bombs) for four seasons with zero issues. I'm currently running Goodyear Endurance. The tires tow the same, longevity and speed ratings are the only criteria I used.
83trekker wrote:when I bought my new Maxxis tires I was advised to run them no more than 5 years because of going bad from the inside. That advice came from a tire dealer I trust and also from this forum.
Well my 5th wheel is 29ft and 10000lbs fully loaded and run 15" maxxis load range d psi65 and no.probelm in around 7 years on the same set of tires.
83trekker wrote:mtofell1 wrote:
My 5th is similar weight and my research came up with Carlisle or GY Endurance. Weight wise check your rims and if they are good for 80psi you should be good with E rated at about 2800# each. Mine stock came with D rated 2580 each stock which is cutting it a bit close IMO. The E rated also have a higher speed rating which was nice. Not that I really go over 65 but it's nice to know I'm not right up against the rating.
How do you know how much weight your rim can carry so i know if i can upgrade my 15" rim to E load?
