rick_flor
Mar 13, 2014Explorer
the 3500 Ram extended cab 8 foot bed dully is rated for 22,000 pounds with the Aisin you are looking at an extra 20% so look close to the fine print, if you tow more then recommended you could have problems with service repairs laterHORSEPOWER
385
ENGINE TORQUE
850
LB-FT
MAX TOWING+
30,000
LBS
MAX PAYLOAD+
6,570
LBS
2014 Ram 3500 Heavy Duty Capability 68 RFE Six Speed Automat
68RFE SIX-SPEED AUTOMATIC
The available 68RFE six-speed automatic transmission is a sophisticated, multirange, electronically controlled transmission that combines optimized gear ratios for responsive performance and state-of-the-art efficiency.
2014 Ram 3500 Heavy Duty Capability G56 Six Speed Manual Tra
STANDARD
G56 SIX-SPEED MANUAL
Modified for increased torque load of the base-output diesel engine, the G56 six-speed manual transmission also carries a wear-compensating clutch for like-new clutch pedal performance throughout the life of the drivetrain.
2014 Ram 3500 Heavy Duty Capability Aisin AS69RC Six Speed
AISIN AS69RC SIX-SPEED AUTOMATIC TRANSMISSION
The available AISIN AS69RC six-speed automatic transmission is an electronically controlled automatic rear-wheel-drive transmission designed to handle higher engine output and increase vehicle weight ratings. With wide overall gear ratios for enhanced drivability and shaft-driven Power Take Off, this innovative transmission will quickly put your work into high gear.
PreviousNext
385
ENGINE TORQUE
850
LB-FT
MAX TOWING+
30,000
LBS
MAX PAYLOAD+
6,570
LBS
STANDARD
PreviousNext
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
