Wood_chip's avatar
Wood_chip
5th wheel Truck combo = terrible ride
It is just painfully rough going down the road. Here are my stats
2015 chevy 2500 Duramax crewcab standard bed ( weighs 8,000lbs at cat scale)
2015 Glacier Peak ( weighs in 10,800lbs at cat scale)
Pin weight 2,200lbs at cat scale 20.3%
Drive axle 5360 lbs
Steer adel 4840 lbs
Truck tires at 80 psi
Trailer tires at 80psi
Bilstein 5100's
"Stable load" spring enhancement kit
B&W Patriot hitch
Standard Lippert extended pin box
Should I try to take some weight off the pin? Should I drop tire pressure ? Not sure where to start? I feel the weight of trailer lunging and pulling the truck pretty bad.
  • You didn't say what the carrying capacity of the truck is after you subtract passengers, luggage, hitch weight ect. Are you overloaded?
