donn0128
Oct 08, 2018Explorer II
Leave the valves in bypass position until your done blowing out and pumping antifreeze thru the lines. Then you can switch back to normal positions. Drain the tank of water and your done. Dewinterize, plug the HW tank, finn, deain as usual. BTW, I normally use water thru the drain hole to flush the crud out of the tank first.
About Fifth Wheel Group
