Artum_Snowbird
Oct 08, 2018Explorer
Never put antifreeze into your hot water tank. In the spring when you dewinterize run the lines out to clear before you allow water into your HWT, then run fresh water into your HWT that still has the drain open for awhile longer. Shut off the input water, plug the drain, open the relief valve, fill it up until it spurts more water, then shut the relief valve and run it out the hot water taps in every location. Shower, sink, bathroom sink and outside shower all on only hot water to clear all the lines.
Then, once you are sure it is all clear, light up the hot water tank and get it hot to make sure it works.
About Fifth Wheel Group
