Learjet
Feb 09, 2018Explorer
needgas$$ wrote:
The side winder pin box replaces the pin on the trailer? I am missing something. The bed sides are the same height as a typical truck box. where is the clearance issue? I thought I might run into issues that the narrow interior may affect the hitch mounting. Am I wrong?
You are correct it is the interior width of your bed that will cause a problem. The recommendation to use a sidewinder pin box is correct from what I have read with the ram box. You then need a hitch that will work with the sidewinder.
Here is a video with the Reese Revolution...same type of design as a sidewinder.
https://youtu.be/ARUdgIO1OWE
About Fifth Wheel Group
