MarkTwain wrote:
Diesel Fuel-
IMHO, when ever possible, it is important to try and use fuel stations that have "Fresh" diesel fuel which means using larger fuel stations. I don't use little small out of the way fuel stations that don't have a high turn over of fuel.
If you're in "ranching" or "farming" country, this usually isn't a problem as a goodly portion of the customer base is driving diesels, so they're getting regular deliveries, even at smaller stations. Even in "urban ranch/farm" areas, where there are horses, you'll see a lot of diesels, so the same applies. Personally, I've never had an issue with what I'd consider "bad" fuel. At the same time, on road trips, I also use Diesel Kleen when I fill up... :-)
Lyle
