batavia02's avatar
batavia02
6-7- 8 k axel ratio?
Question what is the difference between the 6 k axel ratio and the 7 k and lastly the 8 k ratio in the landmark rv. ? I know it is a simple question (hopefully) but I am curious what the difference is thanks
  • Allworth wrote:
    And, keep in mind that only 80 to 85 percent of the total weight of a fifth wheel is on the axles. the rest is on the pin (or the landing legs).
    Which doesn't necessarily mean that the axles can't be near, or over, their weight rating. Some companies will install as lightweight axles as they can get away with.
  • 8k is a larger diameter tube - 3.5 vs 3.0 inches diameter.
  • And, keep in mind that only 80 to 85 percent of the total weight of a fifth wheel is on the axles. the rest is on the pin (or the landing legs).
