rmoparman's avatar
rmoparman
6 point level error
New rig trying to get used to it.
Has anyone run rams all the way out and get error said to retract all?
Was a while till figured it out so i retracted all and cleared error.
I need to bring more wood blocks so rams dont run all the way out.
Ron
  • First time hooking up after leaving the dealer the rear jacks timed out fully extended???? Back to the cheat sheet. Got back to somewhere and retracted the rear and hooked up. No problem at the next campground. Looked like a pro, unhooked pushed the AUTO LEVEL and talked to the neighbor as the trailer did its stuff.
  • Our level up system will read "over stroke" telling me I have to get the blocks out if we're too unlevel.
    Dan
  • There is a learning curve to using these. Blocks sure do help with the shakes.
    Once it errors out you do have to retract all to get it to clear.Great things when they work right as they do if I don't have a user error.LOL
  • i use 6x6 blocks when I can . Less the legs are extended less movement in the trailer. But remember when you in hook that you have room for the trailer to drop when you hit the auto level button. I have made that mistake by putting my blocks under front and it wont go low enough to level
