txdutt
Aug 06, 2014Explorer
Lippert 6 point Auto Level zero point reset
so the last 2 times I've been out with the rig, my auto level system seems to have a brain fart---when I go to hit the auto level it drops the front of the rig wayyyyy down then goes thru a normal extend & adjust but at the end it's not level. I found instructions on doing a zero point reset but there's a part of the instructions that aren't really clear:
ZERO SETTING THE CONTROL
1. Turn “ON/OFF” button “OFF”
2. Push “FRONT” button 10 times,
3. Push “REAR” button 10 times
4. Control will flash & beep, LCD says "ZERO POINT CALIBRATE"
5. To memorize this level condition , press “ENTER”
6. LCD says ZERO POINT STABILITY SUCCESSFULLY SET
7. The control will then turn off.
8. Turn “ON/OFF” on to commence operation.
My question for those who have done this before is do you go into manual mode & level everything first then go through these steps or wait until step 4 to manually adjust--it appears that you need to do the manual steps first but I just want to verify it from someone whose gone through it before...TIA!!
