abc40kids wrote:
So I'll probably put them down and set up just like at the cg. Is it ok if the back two only come down like maybe 8 inches before touching ground? When I back to the end of my driveway the back half of the fifth wheel hangs over higher ground than the rest of the 5er. Seems like it will be ok just will hit ground much quicker than the other 4 wheel.
Uneven ground will not be an issue. That's what they were built for. The feet come down and stop after contacting the ground. After all 6 are down, it does the little dance, first dipping in front (make sure you have pulled your truck forward to clear), then leveling front to back and side to side. As this is going on, you get to stand there with a big smile on your face.
I would get some jack pads to put under the feet if they will be in dirt or gravel. It spreads the weight over a larger area. I carry 6 of the big yellow ones and also 2 sets of the smaller red stackables. You will find there are situations where the legs cannot extend far enough to make your rig level. Then you will need to use the stackables under the leg that can't reach the ground. I use my yellow ones all the time unless I'm on concrete. I especially use them if in asphalt. And I have run into a few places that require pads under the feet - but they had asphalt sites.
Tim
