lynndiwagon
Sep 25, 2018Explorer
Don't need to worry about anything under the tires. In fact, I've been to several sites where the tires were off the ground. No problem. The only thing you might need the blocks for is when the distance the "rams" need to travel for level is exceeded by the slope. In those instances I use short pieces of 4X4's under the lowest spots, but those lego things would work fine.
About Fifth Wheel Group
