Edd505
Sep 25, 2018Explorer
Toolguy5 wrote:
I carry 4 packs of Lego blocks. As well as 6 hard rubber base pads. Depending on how level the ground is depends on how many blocks go under each leg. I only use the blocks on 4 rear legs and use the extension on front landing gear.
Site in Georgetown Kentucky front of 5er was only about 4 inches off the ground where the rear was over 3 feet. My 5er is 42 feet long.
I try and make sure I do not run stroke all the way out on leveling system.
Exactly! I use 3 set but if I ever needed more I would buy another pack.
About Fifth Wheel Group
