Jingus's avatar
Jingus
6 Point lippert but still shakes
I have a 2015 cardinal 5th wheel with the 6 point auto leveling system. After I've auto leveled the rig there is substantial shake throughout my rv and I don't get why it's not stablized. Im on level ground. Wheels not lifted off the ground. I checked level with a level. Any thoughts or suggestions?
  • I don't have the 6pt system, but I understand there is a pretty detailed initialization format that needs to be done before use. Not sure thats the issue but worth a try running through it. Ultimately rv's are still subject to movement as the wheels/springs will compress under load from walking or doing jumping jacks on board. This is despite the feet taking some load off the frame while establishing level.
    Hopefully someone with the exact system can walk you through any possible cures.
    Daryll
