thirtydaZe's avatar
Aug 01, 2015
60" Bed Height
I have a 2013 Ram 2500 with aftermarket wheels and tires.
Currently at the tailgate, the height of my bed is 59-60".
We'll be delivering our 1st FW on wednesday, and im starting to get concerned i wont fit under the hitching area (lack of terminology here). I didnt even consider measuring it.
So i have an appointment today to put my stock wheels and tires back on to be safe, but for the life of me i dont really want to do it if i dont have to.
Is there some sort of standard on the height, and actually being able to back under the FW?
Its a 2016 model.
  • I am making an assumption that this measurement is with tail gate up, correct?
    So if indeed it will all boil down to the hitch height in bed vs. king pin distance.
    I had a concern when I purchased my 2015 GMC because it sat a lot higher then my 2500. I put the B&W hitch at the lowest setting 17" and hooked up to fifth wheel. I am right at a 6 inch clearance of my bed rails. Now when I measured everything before hooking up I thought I was going to have issues. But all worked out fine.
    The truck should compress a littl on the springs once the pin weight gets in the bed of the truck. That was the unknown piece I was not sure of.
  • There's more to it then that. You need to be able to tow reasonably level or you risk s****ing the ground with the back of the fiver. Trucks have been getting taller each year. Definitely put the original tires and wheels back on. You may have to flip axles to raise the trailer as well. Good luck with the new rig.
