bigridetime's avatar
bigridetime
Need RAM 5500 flat bed height
Does anyone know the height of the flatbed on a stock 2022+ RAM 5500?
Doing a new build and considering the Backstop kit, but want to stay under 13'6" if possible, so trying to figure out how high the stock RAM 5500 is.
  • It depends on what brand of flatbed you have. There is no end-all be-all height.
  • 3_tons's avatar
    3_tons
    Explorer III
    bigridetime wrote:
    Thanks for the feedback. I am planning to lift and add some big tires, probably using the Buckstop kit...which will add 7" of height. With a Host Yukon or Mammoth and a low profile A/C unit, to stay under 13'6" I think the bed needs to be no more than 42" high stock.
    Bedlam -thanks for the measurement. if 42" is right, it will just work!
    3 tons - thanks for the info. let me know when you get back in town - would love to bounce some more questions by you.
    Has anyone had the Buckstop kit installed?
    https://www.buckstopinc.com/single-wheel-conversions.html
    Will do…
  • Take a look at RAM truck oem website for “body builder” or “upfitter” manuals. There will be complete dimensions, departure angles, recommend tire clearances, etc etc available.
  • Thanks for the feedback. I am planning to lift and add some big tires, probably using the Buckstop kit...which will add 7" of height. With a Host Yukon or Mammoth and a low profile A/C unit, to stay under 13'6" I think the bed needs to be no more than 42" high stock.
  • Typical deck height is about 42", so about half a foot higher than a pickup bed.
  • 3_tons's avatar
    3_tons
    Explorer III
    I have a 2023 Ram 5500 4x4, 60” C/A with a 9’-4” skirted steel CM bed (90” width) and Eagle Cap 995 with basement…While I can’t provide you the exact number at the moment (I’m currently overseas for another week or so…), it’s just under 13’-6” to the top of the air conditioner, and the CM bed installed rest about 6” taller than my previous rear edge of truck-bed, a 2016 3500 4x4 LB DRW - my garage door is 14’ (13’-10” with moulding)..
    Feel free to PM me if you like…
    3 tons
  • Do you mean from the stock truck frame rails to the ground? I can't answer because I have a 2015 on factory 19.5 Alcola wheels with 4 wheel drive. Asking about the height from the flat bed frame rails to the ground from any manufacturer could get you various answers, all of the right to the respective rig. Maybe this helps?
