Hobo2
Dec 18, 2020Explorer
DRV height
I have a 2016 DRV 38RSSA does anyone know the exact height. Looking a an rv lot with open shed roof but have to get under 13.1 header
NJRVer wrote:My first thought was what you said but not seeing something makes it for a hard decision to give.Hobo2 wrote:
What is the header made out of? Is this the gable end or is the header carrying the rafters?
If it is 2x12's, take it out and replace it with a flitch beam. You could probably downsize it to 2x6's.
Hobo2 wrote:
we Like the great outdoors resort in titusville,fl. There are several shed roof RV lots at 150,000.00 that my DRV would fit under. When i was younger we had a slide in camper that we would drive out on the beach at cape hatteras NC. we would run 15 lbs of air in the tires and go anywhere in the soft sand. There all aluminum building bye the way. The market is hot here with all the NORTHERN tax and spend city dwellers moving here. After 5 years of full timing were looking to park our rv at a nice resort for 6 months a year and have a place close to our kids.
JRscooby wrote:Cummins12V98 wrote:JRscooby wrote:
You might get 2-3 inches from tires. But don't want to leave it set with tires that soft.
Might think about building something like the converter used to pull second of a pair of semi trailers. For walking speed/short distance a plate with hole would work for 5th wheel.
Back in until close to hit, allowing for lift as unload TV. Unhook, push dolly under pin, and lower. Hook dolly to bumper hitch, lift legs, back on in. Put weight on legs before unhook.
Newer DRV's have a flat roof.
Looking at the picture, I see things sticking up from the roof.
Most semi trailers have flat roofs, but when hooked to a tractor the front is higher than rear. I bet the same applies to 5th wheels.
Hobo2 wrote:
I came up with 13-3 ,but was wondering if I could get 3 inches lower bye letting enough air out of the tires before backing under.
