skipnchar
Jun 30, 2014Explorer
It's possible that you have them hooked up with reverse polarity. Lights, water pump etc. won't care but electronic items don't like it that way. MOST systems have a reverse polarity fuse that blows when hooked up incorrectly but not all. Make sure you have the white to negative. I completely agree with valhalla360 that there should be no power problems with a little starting task like a generator. Together they are the same voltage as a 12 volt battery but they MUST be correctly wired with white to negative and the positive and negative leads connected together on the two batteries which turns it into a 12 volt system.
About Fifth Wheel Group
