Vulcanmars
Jul 04, 2014Explorer
Camorhino wrote:Crazy Cooter wrote:
Is the jumper wire connecting the two batteries large enough?
I think Cooter is on the right track here. You need a larger cable between the 2 6volts to carry the amperage needed to start the gen set.
Yep most folks don't realize in a series set up the weakest link be it battery or cables will limit what you get out of the pack.
2, 1000 amp batteries will only get you 150 amps if hooked up with 6 gauge wire.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
