christopherglen
Dec 19, 2013Explorer
What is the rating on your inverter? My 3kw inverter pulls ~300 amps at rated load, 600 at max surge. My 3 85 AH agm's will run the ac, but voltage sags, I get low voltage alarms when surging to start the second AC. If you plan on using your inverter, get enough battery to support it. If you only go from outlet to outlet then any 12v battery will work. The agm just eliminates all maintance until it dies.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
