donn0128
Jul 21, 2014Explorer II
Likely you hqve a CONverter and not an INverter. Look for a metal cover, maybe under the refer. That should be the converter. Had one trailer ther the converter was on the floor off to one side after you opened a door under the refer. Most all trailers are wired in a daisy chain fashion. Power is fed from outlet to outlet. One you find the converter start atthe closest outlet and move around the trailer from there. When you find a dead outlet back up one and check the wiring connections.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 24, 2026
