donn0128
Jul 08, 2018Explorer II
Set it on and auto. It will automatically select the best available fuel source. Electricity being the default. Of no 120VAC is available then it will switch to gas. If on auto it is running on gas then I would suspect no 120VAC is available. Check your breakers, and follow that by checking for 120VAC at the receptacle the refer is plugged into.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
