MFL
Dec 18, 2017Nomad II
It sounds like you are close in your numbers. If you stay under your RAWR/tiremax rating, it should work for you. On flat ground, shorter distance, the older 6.0, with 4-speed 4.10 gears, should handle 10K towing. You should have 3K left for hitch/pin weight on your rear axle and tires.
Not sure what you are describing with the 4 bolt holes being a 2.5' square. If it was a standard type rail setup previously installed, and still has the brackets under the bed, you may be able to go from there. Otherwise, best to start completely over with under bed brackets, that fit standard rails.
Jerry
Jerry
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
