goufgators's avatar
goufgators
Couple of questions...
I have a new (2017) Class C, Thor Freedom Elite 29FE on a Ford Chassis. My first question is this: At speeds of 30 to 50, there's a bumping sensation that feels like a tire out of balance. Is it possible for an out of balance tire to give that feeling only at certain speeds? If not, what could be causing the problem? Question 2: This new Class C has the notorious steering 'wander' that has to be corrected. My first attempt at resolving the problem will be to have the front-end aligned. I've read on this forum that there's a particular (is it?) camber that should be set at certain numbers. Is that correct and, if so, what should I discuss with the person doing the alignment (numbers)? Last Question: Actually, this is a continuation of #2. I know many people have added a number of things to their coaches to correct steering problems such as Steer Safe, front and rear stabilizer bars (believe that's correct terminology). I'm willing to do all of the above if it will show positive results. Please give me feed back regarding your opinions (advice) on these issues. Many thanks!
