NMDriver
Dec 18, 2017Explorer
Check on your data plate for the cargo capacity and GVWR. Remember with a 5er it is the carrying capacity not the tow capacity of the truck that matters.
You will probably be fine with a 10,000lb fully loaded 5er, which means around a 8,000lb empty unit. Finding one to accommodate 5 adults may be the issue, since I am guessing the kids do not want to share a bed.
The hitch holes as you describe them sounds about standard for spacing, but are likely for a particular brand of hitch rail. Basically, there are two rails that attach cross ways in the bed, via the holes you have, to brackets that are attached to the truck frame under the bed. A good hitch installer can probably figure out what you had and with the holes and IF the brackets are still in place you can save some money on the install or some work if you DIY.
From a cost benefit point of view I think you will be better off with a Travel Trailer and a pop up trailer. Get the kids to tow the pop-up when they want to meet you.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
