Ems142's avatar
Ems142
AC Duct dripping noise
I have a Keystone Cougar 5er and I seem to always have a dripping sound coming from my ac vent in the front room. I do not see or feel any water. It makes the most dripping sound when the ac is on and for a brief time when ac shuts off. It tops after a few minutes until he ac kicks on again. Anyone help?
  • Thanks for the replys I went up no issues draining to the back of the rig. I think it's expansion or something. It is coming from the vent in te master bedroom up top. I took pictures with cell phone inside the duct work I see no evidence of condensation or water. I will try to retake the area to see if that helps. I do not hear it around any other ven.
  • Can you see the a\c condensate running off the roof? If not, if you feel comfortable, climb up on the roof and remove the a/c cover. Two screws in the rear and two up front. See if the condensation pan is draining water away as it should. The drain holes may be clogged with leaves\debris the pan is full and what your hearing are the droplets splash.
    Mike
