Old-Biscuit
Apr 16, 2015Explorer III
With AC running......voltage at 108V is the minimum I will operate MY A/C (120V AC +/- 10%=======108 to 132)
A/C fan motor and compressor will operate at much lower voltages...just causes high amp draw and can damage motor
When you started the A/C unit did Fan AND compressor start or just Fan??
Should hear both start.
Could be bad start capacitor/run capacitor/compressor motor.
Turn Fan on manually then turn A/C unit on.......do you hear compressor start?
Air blowing out of duct should start out warm and then begin cooling down within minutes
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
