Coach-man
Apr 17, 2015Explorer
AC unit probably has a slow leak, low pressure in system would prevent compressor for running! Since they are a sealed system, you can not add coolant. There is a dye that can be used to check for leaks, recomend an AC guy check it for leaks. Barring that the start capacitor could be bad as well, but I think you would be able to smell burnt electrical if that were the case.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
