tomthyme wrote:
So sorry I wasn't clear, we have a front AC at 13.5 and a rear AC at 15k btu.
As others posted, you can expect a 20 degree difference between the ambient air in your trailer and the "conditioned" air discharged through the ducts. With two units operating, you may see interior temps around 80-82 degrees at midday, maybe more if your campsite is not shaded or when the sun is at its highest angle. That was my experience with our HitchHiker LS when we foolishly decided to spend a week in mid August at St. George Island SP in the Panhandle and the temps were hitting the mid to upper nineties. I didn't think that was too bad considering the trailer is nowhere near as well insulated as our stick n' brick. FWIW: Even a residential AC system is going to produce a 20 degree temperature differential between interior ambient and discharge temps at the plenum.
