I'm stumped. The rear AC on our brand new 2017 Columbus is "short cycling" but with one caveat. In other threads I've read, this short cycling problem refers to just the compressor turning off whil...
I had the same problem last summer. I used a temp gun to make sure when it was running I had at least a 20 degree difference between outside air and what was supposed to be cooled air. It was not, took it in to the RV shop, now I have a new air conditioner. It was short cycling just as you are saying. They said that it was low on freon. Dometic approved the new air under warranty. Took about 2 hours total.
